Bedlam
Nov 06, 2014Moderator
You need to have proper tool to do the job - There is no reason to spend that much for your application unless you have plans to go bigger at a later time. If you look at the side plates on the SuperHitch, you will understand why it has such a high rating with a long extension. I would not be surprised if just one side plate does not weigh as much as an entire OEM receiver.
