blt2ski
Dec 23, 2018Moderator
Ktsmrf,
The 6500 lb part is tare or empty weight of truck, no passengers, cargo etc on board.
The 10,000 part, as I've read it and understand it to be registered max GVW you can legally run down the road at.
Example, if you had a reg cab 35 series gas rig with 4wd. It's very possible you empty weight is under 6500 lbs. But you may have a max capacity of 12,000 gross. I can see how in the example you could continue in 4wd with correct tires. BUT my 96 sw CC, at 6600 empty, and 05 dually CC at 7200 empty, both with paid for licenses over 10j give, would have to chain up, even if the at that time loaded, gvw is under 10,000 gvw.
Marty
Marty
44,066 PostsLatest Activity: May 13, 2026
