To tighten to 260 ft-lbs, I use my body weight applied to a measured length of a breaker bar. 200 lbs x 1.3 ft = 260 ft-lbs.
First, tighten by hand with a ratchet or breaker bar.
If you weigh 200 lbs, use a socket on a breaker bar extended straight to the side (3 o'clock or 9 o'clock position) and carefully step on it 1.3 ft from the nut, until you put all your weight on it. Keep repositioning it to keep it straight to the side. Have someone else hold the bolt with a wrench and hold your socket in place on the nut.
Take precautions against slipping etc., of course!
