I have run 275/70/18's on my 2015 with zero issues. The tires were EXO Grapplers.
I have been running 285/70/18's on my 18. This took a little more work. The rim offset is -12 so they extend to just beyond the factory frame work. I have Bushwaker flares on it this offset had an effect on the tires. I had to pull the interior wheel well material back and tie it off with zip ties. I also had grind a little off a couple areas that protruded into the tire. Very small and was able to do with the tires on using a small angle grinder. It is tight but looks great. Took a little bit of a mpg hit with these tires over the 275 which was a slight hit over the 265. The EXO's are a HD tire and weigh up a bit more than many others, so depending on your tire your mpg may vary. There is a an offroad company here that makes a front bumper extension that adds some room by extending out the bumper a couple inches. I have a Ranch Hand Legend grill guard or I would do that.
