- bartlettjExplorerI'm running at 65 most of the time. I find that wet traction is awful if I run them higher than that when unloaded. GMC 2500hd crew sb Duramax z71 suspension.
- spoon059Explorer IIII stay around 70 front and 75 rear, all the time in my 2500. My Nitto Dura Grapplers are a little softer than the stock Firestone's were. Seemed to wear pretty evenly like that.
- jus2shyExplorerOK, a long time ago, back in 2013, the RAM 2500's used to have a "Light Load" option. What this allowed an owner to do was run the pressure at 60F, 45R when there was no load, and the TPM would not go off. Then under regular use, you needed 60F and 70R. I have a 3500, I find that my tires wear well with regular 7500 mile rotations at 60F and 55R. The fronts wear more on the shoulder, the rears wear more on the center. With rotation, you get an even wear. Whenever I haul a load of pavers or sand, etc... then it's 80psi rear, front stays at 60psi.
- Ron3rdExplorer III
Me Again wrote:
Michelin Defenders LTX M/S2's work well.
That's the tire I'm leaning towards - Me_AgainExplorer IIIMichelin Defenders LTX M/S2's work well.
FishOnOne wrote:
Ron3rd wrote:
FishOnOne wrote:
I run 65PSI year round loaded and unloaded and got 56k miles on my last set of 20" tires.
It's really that simple.
Fish, what tires are you running?
I've got the OEM Firestone H/Ts and I'll be lucky to get 27K out of them. I'm a little over 26K now and they're close to being worn out. Need to try something that will last next time.
Goodyear wrangler all-terrain adventure. I liked them so much I had a new set installed last month
Sounds good but I'm just looking for a highway tread. Never off road, don't need ano A/TV tire Ron3rd wrote:
Goodyear wrangler all-terrain adventure. I liked them so much I had a new set installed last month- Ron3rdExplorer III
I've got the OEM Firestone H/Ts and I'll be lucky to get 27K out of them. I'm a little over 26K now and they're close to being worn out. Need to try something that will last next time. - I run 65PSI year round loaded and unloaded and got 56k miles on my last set of 20" tires.
It's really that simple. - Me_AgainExplorer IIIOffroad jeeper's have de-flators that are adjustable. However they are not settable to higher pressure ranges. Chris
44,066 PostsLatest Activity: Jul 25, 2018
