Grit_dog
Jan 27, 2015Trailblazer
fla-gypsy wrote:
Too bad you are limiting your choices
Cause he doesn't want a Furd diesel?
While the 6.7 is the best one to date for a while and winning the hp wars, can't say I'd go with the oldest chassis, by a long shot, with the most complicated engine even if I was a Ford guy.
Plus while it won't matter in FL, the emissions systems require the most babying and manual regens and repairs compare to the other 2 with the Ram edging out the GM for emissions reliability in cold (arctic) weather or any conditions with excessive idling and short no load driving.
Doesn't mean any of them a re a problem in general but it's obvious whivh one has the emissions most dialed in based on the fleets I use.
To the OP, you answered your question in the first post. A gasser will tug your big trailer around the low altitude flatlands. A diesel will do it with authority. Add big hills or altitude and you'll want to eat a bullet for getting the one with spark plugs!
44,066 PostsLatest Activity: Jul 25, 2018
