bamafeaver
Jun 20, 2014Explorer
2WD or 4WD
I'm looking at the new cheverolet durmax to pull my fifth wheel. Do I really need the 4WD or should I go with the 2WD. If I go with the 4WD is the mpg a big difference and does the 4WD effective the...
KD4UPL wrote:
Only you know how you will use the truck. I'll never have another 2wd truck. I live where it snow and I often drive on dirt roads in the mountains. I can't tell a difference in ride or handling in my Chevys. Technically the added couple of hundred pounds of weight will slightly lower your towing capacity.
