I'm looking at the new cheverolet durmax to pull my fifth wheel. Do I really need the 4WD or should I go with the 2WD. If I go with the 4WD is the mpg a big difference and does the 4WD effective the...
I never needed a 4x4 for towing but so what we all drive in different areas.
I know the older fords had a problem backing up and the heat made the trannie pour out the fluid because of the high reverse ratio and the low range of a 4x4 was great as the problem didn't happen. I really liked the ratio on our 2001 chev and same for the 05. Easy to back up slow on our 4x2. Not thinking a 4x2 is better of course just that it works for our style.
