I'm looking at the new cheverolet durmax to pull my fifth wheel. Do I really need the 4WD or should I go with the 2WD. If I go with the 4WD is the mpg a big difference and does the 4WD effective the...
It's really just a personal choice depending on what you need. If you drive in the snow then the 4X is going to run circles around the 2WD (and then pull it out of the ditch). There is no comparison in this regard. Been there, owned both - check sig.
