bamafeaver
Jun 20, 2014Explorer
2WD or 4WD
I'm looking at the new cheverolet durmax to pull my fifth wheel. Do I really need the 4WD or should I go with the 2WD. If I go with the 4WD is the mpg a big difference and does the 4WD effective the...
Sport45 wrote:RedRocket204 wrote:wwest wrote:
Other than initially getting up and going, moving, on the slippery stuff 4WD/4X4 drivelines are totally USELESS!
How about geared down engine braking with 4x4 engaged?
To me, your above statement is invalid.
You really shouldn't be in 4x4 mode when towing in a good traction situation unless you have a AWD vehicle. Forcing the front and rear axles to rotate together on a good road is asking for trouble. The best thing that can happen is rapid tire wear. It gets worse from there up to braking an axle or driveshaft due to driveline wrap. 4x4 is for off road or slick roads only. At least that held true for every 4x4 I've owned. Not one was AWD capable, meaning there was no center differential to allow the front and back to track through a different turning radius.
