bamafeaver
Jun 20, 2014Explorer
2WD or 4WD
I'm looking at the new cheverolet durmax to pull my fifth wheel. Do I really need the 4WD or should I go with the 2WD. If I go with the 4WD is the mpg a big difference and does the 4WD effective the...
Wes Tausend wrote:
To the OP, the above discussion on "spinning vs slipping" may not mean much, but there is usually a difference in braking, and therefore handling between 4x4 and 2wd. The 2wd will likely handle better and safer in an emergency on dry roads.
Wes
