Wife and I are in the process of buying a 26-30' fifth wheel and truck to pull it for fulltime use. We plan on doing a lot of boondocking and hitting BLM spots and are wondering if 2WD is enough or...
I've owned both 2wd and 4wd trucks, I've towed with both. All 4wd means is you can get yourself out of the easy stucks. If I found the right "next" truck and it was 2wd, I'd buy it.
All that being said, you "boondocking", I'd go with a 4WD.
