Wife and I are in the process of buying a 26-30' fifth wheel and truck to pull it for fulltime use. We plan on doing a lot of boondocking and hitting BLM spots and are wondering if 2WD is enough or...
Do you NEED 4wd? No, you just have to be more careful where you go. If you did want to keep the 2wd you could outfit it with a winch pretty cheaply which would give you chance if you did get stuck.
