Terryallan wrote:
No you don't need 4x4 to tow. .....haven't been stuck, anywhere. even on wet grass. Which I don't understand how that happens,......
Terry, you're exactly right, 4X4 isn't necessary for towing and can limit towing capacity. But for the times you need it, that feature is priceless.
How do you get stuck on wet grass? I've done it in my back yard. My yard has slopes in every direction and is mostly clay under the grass. Not terrible inclines, but I don't have a flat spot in any direction. I was building a shed a few years ago and backed the truck down to unload wood. It was a little damp after a rain and as I tried to drive out the back the wheels started spinning. I tried to stop immediately when they spun but the damage was done. I had stripped the grass, gotten into the clay, and filled all the grooves in my tires. From that point on I had nothing but racing slicks to drive the truck. I had to use a tow strap and the wife's 4X4 Yukon XL to pull me up the hill and back onto the driveway. I was being careful trying not to break traction but it was game over once that happened.
I've also been stuck in my RAM in 2WD. I had to get my friend's 20' flat bed trailer that was down a hill at the back of his property. After I hooked on I tried to pull up the hill and my back wheels spun immediately on the dampness from the evening dew. Thankfully now owning the 4X4 Ram I just turned a switch, engaged the front axle, and crawled up the hill and back onto pavement.
None of that should prevent the OP from taking the great deal he has available on the 2WD RAM he mentioned. If you watch your conditions and play it right a 2WD truck can be just fine. The main thing is to just know what you have and to watch conditions where you KNOW there is a high certainty you can get stuck.
KJ
