We live near the ocean and there are many pullouts where it is sand and in the USA these are on the right side of the road and so the right rear wheel is always on the ground with the least traction. With 2WD the right rear wheel will be getting 100% of the power as it continues to spin if there is not enough traction.
Ever see the signs posted along the highway that say "soft shoulder"? Well that is to alert people with 2WD vehicles that if they pull over for any reason that they are likely to get stuck.
On snow, on mud, on sand, on boat ramps, 4WD is a blessing. There is also another advantage with those vehicles with 4WD and a transfer case that provides two distinct gear ranges. In 4WD low most will have a 3.7 lower gearing and 3rd gear works like 1st gear in 4WD high. That means I can have the engine at higher RPMs and crawl along to get across a creek or rocky ground at far slower speeds and so if I hit something there is far less chance of damage to the vehicle.
On many dirt roads if there is an incline the rear wheel drive vehicles without 4WD are going to break traction and have a very difficult time making it up. It may be impossible with a rear wheel drive pickup as there is not enough weight on the drive wheels (been there and done that). In many parts of the west the dirt roads that have seen use by people with 2WD vehicles towing trailers are severely rutted and have an extreme washboard effect as a result of all the wheel spinning.
I for one also am more concerned about not getting stuck or needing a tow truck when I am towing a trailer. It gets more complicated and is best avoided. 4WD adds $400 to the price of a new vehicle and you will get that back out in resale value when you sell it.
If your trailer's weight is such that it requires a DRW truck then I can see going with 2WD as you are not going to be venturing off good roads.
