So many theorists on the value of 4wd in snow.
Unless you spend at a minimum a few months, and a few thousand miles a year on frozen snowy roads, you truly don't know...And it's funny to read.
It doesn't sound like the OP needs it's, but it's night and day where I live. 2wd pickups are probably the most hazardous, unbalanced and unstable vehicles on the road in extreme conditions. Where as a 4X4 pickup is one of the best. The 4X4 system messes up the weight distribution even worse than a 4X2, but the tractive effect of 4 wheels in sync, makes a huge difference. It also imparts the ability to pull out of a skid using power, where a 2wd truck has both on throttle, and closed throttle oversteer. The minor tradeoff in handling is understeer under certain conditions, in my experience not any worse than a 2wd.
This is one of the many reasons folks bomb along in 4wd, because until you left off the gas abruptly, they are inherently very stable. Around here, 70mph on snow packed roads with black ice underneath are a way of life. Just because it's unfamiliar to many doesn't make it a death wish or crazy. 4-5 months of real winter means you either learn how to drive, or end up in the ditch, and most folks that hit the ditch up here belong in it.
