boingram
Nov 12, 2014Explorer
2wd vs 4wd
Hi all...time to open another can of worms...we r going to purchase a 2015 2500 denali duramax crew...just don't see the need for 4wd...how abt some non male ego driven opinions on the subject. ..thx...bo
gmc6000 wrote:
Biggest reason for getting a 4X4 even if you don't need it, is resale value. A 2WD is not much cheaper than a 4X4 when buying new. But when the time comes to trade it in or sell it outright, you can't hardly give the 2WD away, nobody want them, not even the dealers.
blt2ski wrote:Brisk wrote:gafidler wrote:
the best thing about 4 wheel trucks is they can be pull by a 2 wheel truck when they get stuck.
Yeah, Ok. That's close......
Depends upon how they are stuck, and what is around......dropped my 88 K3500 right front wheel in a ditch, 4wd could not get me out, but could with a rwd toyota 4 banger to pull it back, as I lifted the front end out of the ditch with my bobcat. voila, truck was free. Yota driver got a kick out of that one! FE was bottomed out majorly! Even the yota driver admitted, his dually Fummins would not have pulled it out in 4lo! it would have needed the bobcat to lift the front tire out of the predicament it was in.
4wd is NOT the end all be all of every situation!
CampingN.C. wrote:
X2 on the gear reduction comment earlier. I've used 4lo before just for that reason. I've read post here in the past where guys have overheated trannys just getting in their driveways.
...being a newbie. ..I apologize for not searching first. ..forget the topic...bo
Grit dog wrote:Turtle n Peeps wrote:As far as 4 wd not helping in turning or stopping, you have obviously never driven in snow with 4wd so don't spout false statements.
I don't have a 4x but I'm still trying to figure out how a 4x stops better that 2WD? :h Please explain?
Well the first part is you don't have a 4x. 2nd part is, even with abs, stability control and all that cr@p, if both axles are locked together, you will get much more stopping power before you lock up a wheel or kick in the abs.
valhalla360 wrote:camperfamily wrote:
Since my truck is a daily driver in NJ and I have to be at work no matter the weather, 4x4 required.
For rving... I've gotten into/ out of spots I could not have with a 2WD. Been stuck 2x on muddy grass. Once 4x4 got me out. The other time the mud was too much and it was uphill. Got pulled out by a friend who's trucks was on the road.
For where I live and the way we camp its a requirement. For others, its not. It's a personal choice that you have to decide on. Think about what you do now and plan to do. Then consider if those plans warrant a 4x4. Make a pro and con list if you want; sometimes they help clarify.
Shocking. I must have been doing it wrong all these years in Michgian where I also must get to work every day...yet 2wd has worked fine.
Then again the OP's tag says he's from Georgia so major snowfall is probably not a big concern.
To the OP: As others have said, if you have to ask the question, you don't need it.
