boingram
Nov 11, 2014Explorer
2wd vs 4wd
Hi all...time to open another can of worms...we r going to purchase a 2015 2500 denali duramax crew...just don't see the need for 4wd...how abt some non male ego driven opinions on the subject. ..thx...bo
BenK wrote:
Nylon tow straps are DANGEROUS if you don't know HOW2 use them
ford truck guy wrote:MPond wrote:Gdetrailer wrote:
Pretty simple. I personally know quite a few people that bought 4x4s and don't have an idea as to how to engage 4x4.. These folks own lifted "boulevard queens" with wagon wheel rims and way oversized tires, drive in the city, their trucks have never touched dirt let alone mud.. Happens a lot more than you think..
So you have anecdotal evidence, just like I do. Only my anecdotal evidence is just the opposite of yours.
I wonder if there are any real statistics about it around? Would be much more interesting that either of our opinions...
AND in MY CIRCLE everyone who has 4X4 uses it many times a year ,between the weather , and surf fishing...
benk wrote:
Why I dislike tow straps or really how folks use them and store them.
Sand/dirt/etc is very bad 'cuz it makes micro cuts in the fiber
Plus, the way folks use them is to take a running start to sling shot (rubber
band) someone out.
Sling shot, or rubber band, has tons (literally) of energy and if something should
come off, this can happen
Ever wonder why the recommendation is to have a blanket tossed over
the tow strap? Even steel cable should have a blanket as a parachute
but steel cable doesn't have as much stored energy (stretch)
Plus these folks are breeding...
Turtle n Peeps wrote:Grit dog wrote:Turtle n Peeps wrote:As far as 4 wd not helping in turning or stopping, you have obviously never driven in snow with 4wd so don't spout false statements.
I don't have a 4x but I'm still trying to figure out how a 4x stops better that 2WD? :h Please explain?
Well the first part is you don't have a 4x. 2nd part is, even with abs, stability control and all that cr@p, if both axles are locked together, you will get much more stopping power before you lock up a wheel or kick in the abs.
You not only were mistaken about how a 4x system works and when it's safe to use it you also don't have a clue on how ABS works.
ABS will not let any wheel lock up. That's what ABS is for. it's designed so no wheel locks up. If all the wheels are locked together the ABS will find the one with the least amount of traction and will not let that wheel lock up. Since they are all locked together even the ones with good or better traction will suffer from less braking ability.
Thank you for listening in to the ABS and physics lesson of the day. :B Please sign the guest list on the way out. :)
MPond wrote:Bedlam wrote:
If you have not at least tried beach camping once, you will never know if that is the type camping you want to do again.
The first video was of campers that got trapped when the tide was coming in. If they did not make that run, the water would eventually reach them. It was poor planning on their part to be on that section of beach without knowing the tide tables. We ride the Oregon coast in off-road vehicles always make sure we are aware of the tides and where the exit points off the beach are located.
There are times when you hit a soft dry patch of sand where even 4wd does not help you. This why you use a buddy system to help each other out. If your buddy had 2wd in these conditions, he would be more of a hindrance than help.
Both videos are from Pismo Beach, and they weren't trapped at all at the river crossing - just impatient and not willing to wait for low-tide. You can wait on either side of the river crossing above the high-tide line without any problems. When the tide goes back out, it changes from a river to a stream...
And if you air-down properly, you can take a heavey rig w/4wd through the softest sand. I've taken my 5-er (around 17k lbs at the ime) & 4x4 Duramax on that very beach. With all 12 tires aired down to 13 lbs, I easily drove it all the way out on the soft sand to the base of the dunes. The problem with the 2nd video is that it appears they have not aired down.
Turtle n Peeps wrote:ford truck guy wrote:
Hey BurbMan ,
Where is that spot ???
I always wanted a 4 wheel drive so I could do this while camping. This guy gets the good spots all the time!
This looks like great fun if you have a 4 wheel drive!
