Typically, (I can't speak to Fords system as I don't know it) regen is triggered by a pressure sensor on the DPF. Frequent regen can be a sign of a plugged DPF, or faulty sensor.
It may be worth taking your truck on a long hard drive with high (safe range of course) egt and rpm. Perhaps lockout overdrive or your top gear. Generate lots of heat and burn the dpf out.
I Know that the ecu on Ford agricultural equipment can be set to do parked regen, it makes the pipes glow... Might be an option for your truck as well.
Or, maybe it's time to delete. (delete and other tampering with pollution control may be illegal, this advice is at your own risk.)
