westend wrote:
I'd suggest to keep an eye on your battery. You don't make mention of what you're doing when the TT is in storage but if the battery is connected to the TT and allowed to sit for a couple of weeks, it will be dead. Do that a few times and your battery will be a goner. Some folks either pull off a battery cable or install a disconnect switch for storage. Some also leave the TT plugged in with the converter charging.
Thanks! I will absolutely keep an eye on it for sure. My TT does have a battery disconnect knob, which I use while the camper is stored. Hopefully that helps...
