macdale4's avatar
macdale4
30 amp Marineco Connections
I just bought a new TC and it has a Marineco 30amp connection. The female end broke and I've tried two Camping world connections and a Marineco adapter to a standard 30amp plug and it won't make a permanent connection. If you twist it just right electricity will go through to the camper and as so as you step in the door and it jiggles, the connection is lost.
Any suggestions, let me rephrase that for all of you wise guys out there, any HELPFUL suggestions.
Thanks.
  • You could have a loose connection inside the connector where the wires attach.
    Try to take the unit apart.
    Does your cord have the black locking ring?
    Yes, marine supply store should be able to help.
  • I'd try a West Marine or Boater's World for connectors, but I'd first take a look at the end of the connector to make sure the wires are solidly connected and not corroded.
