Doug33 wrote:
On our last stay in Delaware, we were having all kinds of problems with tripping the circuit breakers and the A/C was struggling due to poor delivery of electric in the CG. Because it was hot and the CG was full, I believe they had a peak draw that their system couldn't handle.
You absolutely need to get a voltage meter. Check the minimum voltage that your unit can use, usually 104 to 108 volts. If the voltage is too low do not operate the AC. An autoformer can be used to boost voltage if needed, but they ain't cheap.
