Huntindog
Apr 15, 2015Explorer
I had a 40 that was recalled. I now have a 50. I would get the 50. It is all about the speed in which it removes moisture from the air. The warmer you run the heat, the more showers you take, the more people/dogs you have, the bigger is better thing works well here. A TT wth it's small interior can spike high humidity pretty quickly... And you need to reduce it pretty quickly as well. The only downside to a larger unit is it's physical size. Other than that, it just works better.
44,067 PostsLatest Activity: Jun 05, 2026
