4x4ord
Nov 26, 2016Explorer III
30,000 lbs behind the Ram
Clicky The Rams time was almost exactly what I expected out of a 385 hp engine. Using the same formula the 440 HP Powerstroke should have made the run in 10.5 minutes.
It just doesn't make sense. You let up on the accelerator to tell the truck you want it to pull harder??? Obviously if the engine is revving high, letting up on the skinny pedal will encourage it to upshift. I think Mr Truck has been sucking in too much diesel smoke.
