4x4ord
Nov 26, 2016Explorer III
30,000 lbs behind the Ram
Clicky The Rams time was almost exactly what I expected out of a 385 hp engine. Using the same formula the 440 HP Powerstroke should have made the run in 10.5 minutes.
ShinerBock wrote:transamz9 wrote:
Because rvers are not the main class of people these trucks are built for. A load of livestock can easily break 30,000lbs.
I am not just an RVer either. I help my ageing father in law with his 500 acre ranch/farm with over 50+ head of cattle so I know a thing or two about hauling cattle. I will have to say that I have never ever ever in all my years seen a 30k lb load of livestock being pulled by a 1 ton truck. Even most of the long 32' stock trailers have a max GVWR of 20-22k lbs.
Most big ranches around here that have to haul that many head to the market generally has something bigger than a 1 ton so they can haul more than just 30k at a time.
