4x4ord
Nov 26, 2016Explorer III
30,000 lbs behind the Ram
Clicky The Rams time was almost exactly what I expected out of a 385 hp engine. Using the same formula the 440 HP Powerstroke should have made the run in 10.5 minutes.
transamz9 wrote:
Hauling to market is one thing but around here the farmers haul from farm to farm and they do it with their pick up trucks and I promise you a 30,000# trailer load of cattle is not uncommon behind a 1 ton truck.
Even at that, my point is that RVers are NOT what these truck manufacturers are marketing to. How many 500# bails of tobacco do you think you can get on a 30' deck? Hay? Tractor with implement? Then you have construction. We pull 30,000# trailers quite often with "1 ton" trucks and cross the scales with them. Believe me, it's more common than you think and now we can do it with trucks that are "rated" by the manufactures to do it.
