4x4ord
Nov 26, 2016Explorer III
30,000 lbs behind the Ram
Clicky The Rams time was almost exactly what I expected out of a 385 hp engine. Using the same formula the 440 HP Powerstroke should have made the run in 10.5 minutes.
ShinerBock wrote:drittal wrote:
Local racer uses a KW with a huge custom sleeper to tow his rail car. Licensed as an RV with "Not for hire" decals and no CDL needed.
That is because it is licenced as an RV. I am talking about regular everyday DRW pickups licences as pickups and towing a trailer with a GVWR greater than 10k. Per regulation, if it has a GCWR greater than 26k, then a CDL is required. Again, recreational vehicles are different.
