4x4ord
Nov 26, 2016Explorer III
30,000 lbs behind the Ram
Clicky The Rams time was almost exactly what I expected out of a 385 hp engine. Using the same formula the 440 HP Powerstroke should have made the run in 10.5 minutes.
4x4ord wrote:?? My 2011 is over 26K. The newer stuff is by more.ShinerBock wrote:drittal wrote:
Local racer uses a KW with a huge custom sleeper to tow his rail car. Licensed as an RV with "Not for hire" decals and no CDL needed.
That is because it is licenced as an RV. I am talking about regular everyday DRW pickups licences as pickups and towing a trailer with a GVWR greater than 10k. Per regulation, if it has a GCWR greater than 26k, then a CDL is required. Again, recreational vehicles are different.
Well if RV's are exempt than all is good. Those who need a dually to haul heavy loads are happy. Those who want a dually to haul their RV are happy. So, it's only those who want a heavy truck and trailer to drive around empty that are annoyed and I guess they can buy a GM.:)
