vlopddap
Aug 22, 2018Explorer
SoundGuy wrote:
The next step up from 30 amp service is 50 amp which in fact is 50 amps per leg across 2 legs - BIG difference, 3600 watts vs 12,000 watts. Here in Canada 50 amp service is much less common than in the US, usually only found in private parks and rarely in provincial parks, national parks, conservation areas, etc. In other words, much more limited choices when selecting a site if you insist on 50 amp service and at the end of the day one would often be limited to a maximum 30 amp draw anyway regardless of whether the rig itself is wired with 50 amp service.
Sure... I understand that, but my question is not exactly how to upgrade from 30A to 50A panel (and what are the consequences), but it's to understand how to manage all these equipments with only 30A of power for the entire trailer.
More important; I assume that if the trailer is equipped that way from the factory, it's because all things are supposed to work together? Isn't it?
44,057 PostsLatest Activity: Mar 12, 2026
