hawkeye-08
Aug 22, 2018Explorer III
A number of solutions given already, but make sure your power is not too low (lower volts will cause increased amps for the devices. If you want to check and make sure all the connections are properly tight (loose connections cause heat which uses power which is not available to the devices)..
Perhaps change the water heater element to a lower wattage one as well.
In the two trailers we have had (still have one), I have never tripped any breakers.
44,057 PostsLatest Activity: Mar 12, 2026
