Boomerweps
Aug 23, 2018Explorer
I've found that LONG wire runs WILL cause voltage drops significant enough to cause amperage draw increases to trip circuit breakers. Turns out my last trailer parking spot ended up with a total of 195 feet of 12awg wire from the house breaker box through the garage to the TT. Dropped the voltage to about 105-107, best I could measure when testing. My garage large security light photo sensor went spastic went the TT AC & Fridge were on. During daylight with the fridge & AC on, I popped the 20 amp CB in the house when running a small hand vacuum cleaner in TT. Not going to park the TT there again! It'll still be about 75-80 feet of wire to the TT at the new spot.
I plan on copying another poster's modification by adding a separate 20 amp AC inlet on the side of the TT to run to a duplex or quad box of its own. Already ordered the AC inlet via Amazon for about $15 USD. So I can then plug in any heating element devices to there own source at campgrounds. I always run a seperate AC line to my outside under awning table, vice using the TT's outside convenience outlet, for electric fry pans and such.
