cbshoestring
May 10, 2022Explorer II
IAMICHABOD wrote:cbshoestring wrote:
I have to shut mine off when we boondock for four wheeling trips. The generator trips the unit for "open ground".
I'm normally only using the trailer for sleeping....with a space heater for heat. Maybe a bit of t.v. as I nod off. So I figure nothing important will get fried.
There is a way around that, so you don't have to bypass the EMS,just make or BUY a grounding plug for your generator.
This Thread may be of help to you if you are interested in doing it.
Thank you.
I normally use CG pedestals with the better half, but have recently started making 1 or 2 trips a year with the brothers to do a bit of ATV riding. One brother kindly shares his generator, as we both set up for minimum power usage.
I may have to add a plug to the collection....we all keep.
44,070 PostsLatest Activity: Sep 18, 2026
