Probably going to buy 2013 F150 Crew Cab 4x4 w Ecoboost. Dealership has 2 that are priced about the same, but the one with more options only has 3:31 axle ratio......Other one with less options has 3...
Check payload 1st. 4.10's won't matter if you don't have the payload capacity for the tongue weight, WD hitch, family and gear in your truck. 7400lbs equates to 9-950lbs for tongue weight. Then add 100lbs for the WD hitch. Now your at 1000lbs. If you aren't getting the Maxtow then your payload will be in the 14-1500lb range. Add up the family and whatever else goes in the truck and see how close you are. Where are you putting the BBQ, lawn chairs, firewood, etc.
