hey folks I hauled the Empire state building in the back of My 3500 SRW the other day, couldnt tell it was back there.HA,HA,HA,HA!!!!!
REALLY!!!
I have owned 2500HD, a 3500HDDRW, and now a 3500HD,SRW. would have to say that each one towed a bit different and they share the basic same engine/trans, frame rails,axle housings with a little variation in spring packs and tires. I promise if You put an actual 2000.lbs in the bed even the dually will drive different. now will they handle a 12k,14k,or 15k 5ver with a 2500lb. pin weight? probably,so I split the difference My 5ver is a bit under 14k and My 3500 srw handles it well. just have to think and drive safely how ever You load it.
