batavia02 wrote:
3/4 ton duely vs 1 ton srw, what are the pros and cons of each.I know you can't ever too much truck but.in this case the truck will also be the daily driver.yes we are looking at a diesel,.5th wheel max weight is 17k at most.thanks
You didn't mention cab size.
I'll assume diesel crew cab...?
The Ram 3500 SRW 4x4 crew cab is rated to tow 17,200 lbs.
The Ford F350 SRW 4x4 crew cab is rated to tow 15,700 lbs.
The GM 3500 SRW 4x4 crew cab is rated to tow 17,100 lbs.
Will the DRW be more stable... probably. Do you NEED it... doubtful. If this is your DD and you have to worry about daily parking and possibly city driving, a SRW will work.
