- work2muchExplorerHelwig says they should have a product/part number in about 2 weeks. Hopefully this will be a very valuable upgrade for our truck.
- work2muchExplorer
Gary3 wrote:
Good news for those with sway problems just read on the LOA site Hellwig is near completion on a rear swaybar for the factory air suspension on 3500 Rams.
I just sent them an e-mail again regarding this. Interested to see. I think it would just involve an axle clamp that would be relieved around the factory air lines. Will post if there is a response from HW - work2muchExplorer
Intersted for sure! Link? - Gary3ExplorerGood news for those with sway problems just read on the LOA site Hellwig is near completion on a rear swaybar for the factory air suspension on 3500 Rams.
- OutdoorAddictExplorerI have had a 2500 with air and now a 3500 DRW with air. The 3500 is much better than the 2500 because it works with leaf springs. True, currently there are no after market suspension products that you can use with the factory air ride, but I have found no need to upgrade the suspension and I am hauling a AF 1150 and often tow a boat. The Only downside to the air is that you cannot add air to just one bag to offset the additional weight of the slide, I have a very slight list to the side of the slide with TC on truck. I don't think cold weather affects the air bags because the bags work on a closed system and are filled with nitrogen.
- GpnAZExplorer
Gary3 wrote:
Is the factory air suspension completely auto or do you have to push a on off button when you load the camper.
It's completely auto, there is a button to lower the suspension, but when button is on, it will auto level as soon as you load the rear. - Grit_dogTrailblazer^ Exactly, so it is not of any use in add on airbags unless they are plumbed together and likely not useful for Ram air assist as I believe that is separate lines per side.
- Gary3ExplorerIs the factory air suspension completely auto or do you have to push a on off button when you load the camper.
- notevenExplorer III....
- burningmanExplorer II
stevenal wrote:
My experience with a factory air suspension was with a '97 light duty F250. They would blow, frequently. And since it was an integrated system, loss of a bag left one with a very harsh ride with the frame sitting on the stops. It got to where I began carrying a spare bag, and ultimately had a spring shop add a few leaves. In my opinion, air bags are better as an aftermarket add on.
That’s like saying “My ‘76 Vega was junk, so, all cars are junk”.
Almost every big truck runs on air bags. They’re extremely reliable.
I’ve had air bags on pickups for decades. My own pickup has an air ride conversion on the rear, plus regular overload-type airbags too. None have ever failed.Grit dog wrote:
If not air assist, what would you call it? When I think air ride, I think air only , not air over springs.
The springs merely locate the axle. Something has to. The airbags take all the weight.
Donvel valves control the rate air flows through them and work wonders for ride quality, but they only make big-truck stuff as far as I know.
44,070 PostsLatest Activity: Jul 01, 2022
