HioSSilver
Sep 16, 2017Explorer
3500/2500 srw or drw
I've been thinking of upgrading my 845 lance camper to one with a slide. Preferably a 971 or similar dry bath camper. How stable are the srw trucks with the additional weight?
TxGearhead wrote:
"That is why heavier diesel will have lower cargo rating as nobody wants to pay registration for what the truck can actually handle."
I always assumed it has less payload because the diesel is so much heavier.
GVW-actual weight=payload
Not every state has expensive registration costs.
Kayteg1 wrote:
Why the hesitation to get dually? The fuel usage on them is just slightly higher than SRW , good tires last 100,000 miles, they park on normal parking spots (unless you get Crew Cab) and this way you save time by not posting endless questions on the forum.
HioSSilver wrote:
Thanks for all the comments guys. Still unsure.....I'm kinda in the same boat as vinsil. Not really interested in driving a dually all the time. But i would like a 9xx truck camper with a slide and a dry bath. I don't get to go alot. If i were full timing in it i would do a dually for sure. But i don't want it to be unsafe or put myself in a bad situation.
hedge wrote:
I just moved from a SRW to a dually. Not sure how but when loaded my SRW was almost at tire capacity and almost 1000lbs over GVW. This was with a 9' camper. I camp a lot in BC and they can scale you, they go by GVW... but I believe it is a very rare occurrance.
I like not even having to think about it with the Dually. I really had no adjustment period getting used to the width but the length is a different story. I am actually sort of regretting going to a 450 with the wide track axle and much tighter turning radius.
