jimh406
Oct 27, 2022Explorer III
Baja Man wrote:
The tubes are separate pieces. The lower tube inserts into the lower receiver hole where you then line up holes and insert 5/8" pin. It is the lower tube that was not drilled correctly.
That aligns with what I was thinking, but if you loosen the straps, can you not get enough play to align the lower pin? Then, tighten the straps that hold the tubes together.
