Baja_Man
Oct 27, 2022Explorer
jimh406 wrote:Baja Man wrote:
The tubes are separate pieces. The lower tube inserts into the lower receiver hole where you then line up holes and insert 5/8" pin. It is the lower tube that was not drilled correctly.
That aligns with what I was thinking, but if you loosen the straps, can you not get enough play to align the lower pin? Then, tighten the straps that hold the tubes together.
We never even connected the two tubes together. We simple inserted the lower tube by itself and the hole did not align.
