What are the "different parameters that each sensor handles?"
Ford's PCED Service Manual states that the PCM processes the output of all three sensors to control the
same parameters, and Ford lists these identical parameters clearly and specifically: ie, torque converter clutch, shift scheduling, electronic pressure control, etc, as listed in the post above yours.
Do you have any more specific information regarding what "different parameters" you are referring to?
dodge guy wrote:
Each one of those sensors does handles different parameters in the truck. by changing one it will not upset the other.
