well I tore my floor up what a mess. Took the rotten boards off the bottom of the laminated walls a little delamination not bad. was going to use 3m marine 5200 to reattach new boards on the bottom of...
Not sure if 3M5200 isn't over-kill for this application. It's great for exterior, even under-water applications, but wouldn't a standard construction adhesive be ok for this, assuming it's all interior and the leak has been fixed.
Also 5200 and any construction adhesive that comes in a tube is pretty thick stuff. There are thinner construction adhesives available if necessary.
