How do you keep the water lines from freezing while traveling? I am considering a NL or bigfoot basement style camper. My travel will include driving two 14 hour days to get to North Dakota or Mont...
The only place I have had trouble is with the water in the water pump freezing with successive days of temperature in the teens. If I wanted to prevent this I would leave the water tap on so water would trickle out and the water pump would kick on at least once an hour. The water in the holding tank is going to be warmer than the water in a small line where there is a more surface area.
We keep a couple of 2.5 gallon fresh water containers for use as a backup.
