schlep1967
Dec 30, 2021Nomad
Any camper you buy will have the ability to freeze and burst water lines if you don't heat it. Just like a house does. If you are not going to run the furnace you will need to use antifreeze in the lines.
A four season camper means it can be used, if used properly, in the winter. Using it properly means running the furnace to keep water lines from freezing. Using the onboard water tank since leaving a hose hooked up outside in freezing weather will not work. Among other things you will have to learn if you intend to camp in the winter.
