ajriding
Dec 30, 2021Explorer II
Yep. Your house will freeze and burst pipes if you turn the furnace off and let it get cold inside.
Same for camper.
4-season means it is able to be used in the winter, but you have to keep it warm. There are campers with pipes and tanks outside that cannot be kept warm unless the under side is enclosed and heated, those are not 4 season.
There is no camper that can protect wet pipes when the heat is turned off.
Same for camper.
