rtk2
Dec 30, 2021Explorer
A four season camper is an advertising myth.
Without a lot of propane and access to AC power, you will shortly freeze solid.
Even with propane and power, access to fresh water fill and sewage dumping will be almost non-existent.
I live in Alberta and know that you are currently at minus 30 C in most parts of the prairie.
Yes, similar to windshield washer antifreeze, adding plumbing antifreeze will keep the grey and black tanks "slushy"
Best bet is to not use any water in your unit. Just jugs of potable water and a drainage basin that you can dump. A portable toilet is possible if you need it.
