Geodude wrote:
In Ontario, a pickup truck is defined as having a GVWR 6000 kgs and under, and at that weight there are no personal use exemptions of any kind, you're 100% commercial. The GM dually has a GVWR of just under 6,000 kgs so it hits all my numbers and I don't need a CVOR.
Bummer. Doesn't Ford offer different GVWR packages anymore? I know you used to be able to spec out a F350 at 2 or 3 different weight limits, even though there was zero mechanical difference, just to get around these types of arbitrary designations.
On another note, you lose headroom as you gain trim cost in a Ram? I never knew that... but then again I have a Tradesman!
