PA12DRVR
May 28, 2020Explorer
Different year, different model, same mfg, same problem....both a position sensor switch and related solenoid went bad overnight: lever moved fine, nothing happened in the innards.
Straightforward fix (doesn't mean inexpensive) at the local tranny shop; most challenging part was getting the vehicle out of the condo parking lot. Ended up with a "come back at 10:00 p.m." charge from the wrecker as well as a couple of PO'd neighbors since it was unavoidable to block one road for about 15 minutes.
44,056 PostsLatest Activity: May 04, 2014
