Looking at buying a used diesel PU. I don't really need 4WD, but there aren't many 2WD for sale. I am looking at getting a Ram 2500 Diesel from 2006 to 2010. Are the 4WD Ram 2500's taller than the ...
From a currently running thread in this section: "Oil sender failed, cluster failed, transfer case seal failed, front hub/bearing failed"
I wonder if "very little additional maintenance" really applies.
My 2WD truck doesn't have a transfer case, or front hubs, or front u-joints or CV joints, front drive shaft u-joints, front differential seals, or additional fluids. So, none of that stuff has failed on my truck nor needed to be maintained.
