I plan to purchase a new tow vehicle within the next two years. At the present time, I am towing a 3500 lb travel trailer with a 2006 Honda Pilot 4WD. The 4WD is Honda's name; actually, it is AWD wit...
one thing they have said is true about shifting on the fly but only the 4 wheel high not 4 wheel low. You have to stop and put the truck into neutral then shift to 4 wheel low then back to a forward or reverse gear. you must be lower than 5 mile per hour to shift to low range.
