I plan to purchase a new tow vehicle within the next two years. At the present time, I am towing a 3500 lb travel trailer with a 2006 Honda Pilot 4WD. The 4WD is Honda's name; actually, it is AWD wit...
I have a '99 F250 4wd with shift on fly. I also have an H2 which is AWD/4wd, I wish it had a 2wd option as it would be better on fuel. It has hi&lo range in 4wd and rear diff-lok . They are very different animals. Not all 4wd systems are the same. Fords have locking hubs. Rams have Center Axle Disconnect (CTD) which disconnects the axles from the diff, but the axles still turn with the tires. Something else, if it has traction control- make sure it can be turned off.
